F***!!!! Stripped union bolt
mnmlst
104
edmonton AB
GOD DAMNIT!!!!
I stripped another freakin bolt.
This time it is the union bolt (or the threads in the block???) for the turbo
I want to go back in time, holy SHIT IM PISSED
what do i do, if i tap it, a new bolt is going to be too small won't it?
mnmlst
104
edmonton AB
I know, I triple checked..
I must have gotten distracted when I calibrated my inchpound wrench and then I set it down..
Did a conversion and picked up my footpound wrench, and went to it.. But she was still set at 33 from the turbo mount nuts :(
I EVEN did a feel test on my old N/A block.. but when the union bolt got suspiciously taut + stripped I was hopeless.
I make these stupid tiny mistakes all the F'in time
EDIT...........^HUGE MISTAKE
mnmlst
104
edmonton AB
do helicoils/time serts work for something like a banjo bolt thread?
T_T
it appears the hole goes deeper than the threads of the banjo bolt, would a longer bolt still work?
You can try but I highly doubt it. It's cast iron. Not something easily fixed.
Any pics of the threads in the hole?
toyotanos
What will we break today?
2,842
Coon Rapids, MN
You might be able to find a longer banjo bolt to bypass the damaged threads, although I'm unaware of such a bolt. I wouldn't try to make your own, that would likely end in tears.
mnmlst
104
edmonton AB
I dont know the thread pitch, would it be 1.25 like most other things on the engine? I guess i've got to try some kind of threaded insert
from looking at the pictures i have come to realize the threads are only as deep as the banjo bolts.
I am thinking time sert/helicoils inserts are my only option.
any ideas/thoughts on these threaded inserts?
mnmlst
104
edmonton AB
i revoke my previous statement, the threads in there do appear to run deeper than the threads on the banjo bolt
its possible a longer bolt would work, but will I be able to line up the banjo hole... where would I find such a bolt..
no cracks, took a good look
tight space due to oil filter piece, will be a very tricky fix :(
super51fan
497
Indianapolis
I don't think GOD had anything to do with it. If it was anything it was the devil.
Step one is to run a tap into hole to clean threads. Make sure you put grease on tap to hold metal shavings.
I would buy a new "banjo" bolt. I did see a 26mm long banjo bolt on the web. Don't know how liong the factory one is. I would get one from Toyota.
Reinstall and see if it will hold the torque. I would say about 22 to 25 range would work. I did not look. This is one bolt I have never torqued. But you should.
If it holds great.
If not it is insert time. Oh what to do with metal shavings?
IMO good luck.
atmperformance
757
San jose
I bough a replacmen banjo bol that was slightly longer tan stock but my AN adapter fitting is even longer, just a reminder you can switch out to a AN fitting and this could open up more options for your thread.
DeMoN2318
572
Arizona
AN fitting option seems like the best route.
But if you want to stay with the banjo bolt, you might contact a brake line manufacturer (like goodrich) they have a HUGE array of bango bolts for their many differnt brake like applications.
mnmlst
104
edmonton AB
Wow, to think last night i was completely hopeless, and now I come home from work to a bunch of options.
goes to show how this website ROCKS MY WORLD
*mad love*
What is/how do I install this AN fitting?
stock banjo bolt is 1 inch and 3/16 (my metric tapes r at work -.-) , so roughly 30mm long
im not sure how the longer bolt would work? because it looks to me like the deepest threads are the damaged ones
DeMoN2318
572
Arizona
If the deepest threads are the damaged ones then I dont think the longer bolt option will work.
The AN option, I have little experience with AN fittings into a blocks, so I will let others chime in. I am sure there are several ways to go about it, so hopefully someone with experience can set you in the right direction.
But I say there is definitely hope
