External oil pump
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Hey,
I am very interrested in trying to run an external oil pump. How much am I looking at here? What are all the parts I will require? What is the difference in dry sump and wet sump? What do the ymean?
eric
ma71supraturbo
Redding, CA
www.geocities.com
a wet sump has the oil stored in the oil pan. A dry sump plumbs the oil to an external resevoir. This keeps oil from getting churned up in the crankshaft, as well as keeps the pump from getting starved during high g-force situations that would cause the oil to slosh away from the wet-sump pickup. Downside is cost.
Stretch
Toronto, Ontario
So now that I know what a wet and dry sump are, can anyone tell me where I might beable to get some prices on parts, and possibly the parts tha twill be required?
eric
Have a look at Aviad's site and Moroso's for starters.
Fabricating the parts needed is going to cost a bundle.
Put a post in Defiant7M's thead as well he'll be running dry on his stroker.
siman
Lifetime Ban
Murfreesboro, TN
I dont see a "noise" problem with them, knowing that the new Corvette ZO6 has a dry sump system from the factory....somehow they had to make theirs "quiet"...
the dry sumps i have heard ( inside of cars) are not loud at all.....I mean, if you have a full ( straight piped) exhaust system...i DOUBT you will be whining about the dry sump systems "noise".... :icon_excl
