Explain Amp-Hours to me please.
Justin
Speakers?
Spokane, Wa
I have a Makita drill set that has a 3.0 aH battery and I just bought one that has a 1.5 aH battery.
I know(think) that is has to do with duration or longevity of the battery under full load but I'm clueless after that.
I was also told that it was the duration the battery could last under full load. So the 3.0 would last 3 hours under full load and the 1.5 would last an hour an a half under full load.
Anyone care to clear it up for me?
flight doc89
Registered Murse
Apr 21, 2006
227
Bessemer, Alabama, United States
shows how long the battery can supply a certain current; ie, how much juice is in the battery.
theoretically, a 5 aH battery could supply a 1 amp current for 5 hours, or a 5 amp current for 1 hour, at a defined voltage.
If I am mistaken, someone correct me.
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Remember, look how much of a load [amperage] the drill actually eats, and keep in mind that these are just numbers so you aren't disappointed. Heh.
Isphius
Supra-less :(
May 30, 2006
359
long branch
flight doc got it, but im sure the drill can use a lot of amps. I think RC car motors are similar in size/power and can draw 30-40 amps
