Hello all you experts. I have a problem and if anyone can help me track down and fix the problem I have $10 via paypal waiting...
My sweetheart of a girlfriend got me a mini-kegerator for my birthday and it doesn't cool. It appears to have been manufactured in 07, but it's brand new/never used.
I'm trying to fix it as she got it shipped and I'm sensing ebay or something and it will not be easy to return.
I've done some basic diagnostics:
-Unit powers up, fan runs, but does not cool.
-A small square piece glued to the bottom of the container with two leads (red/black) gets EXTREMELY hot as soon as it's turned on. This piece has a big heat sink/fan on the back of it. What is this?
-There is 12V to the main circuit on the board.
-There is a pump wired to a high pressure switch and the pump only sees 0.5V when the unit is turned on.
-There is a squishy piece of tubing attached the pump-pressure switch and it is very limp. i.e. no pressure.
This is the pump, you can see the white soft hose coming out of the top, the leads are at the bottom. Yellow wire goes to the pressure switch.
This is the pressure switch.
This is the flat piece that gets VERY, VERY HOT immediately when it's plugged in.
Heat Sink:
What kind of cooling system would this thing use? How could I re-pressurize the system if it's lost pressure?
I'm guessing there is no pressure. The pump is only connected to one hose so maybe it's an air pump?
I'm a bit lost at this point and I'm really hoping to get this working. It's brand new (old shelf stock) and I know it wasn't cheap on my g/f's first year teacher salary so I'd love to get it working.
Thank you in advance for any help and like I said, if you can give me the solution and it works you've got $10 coming your way.
-Andy
Heat Sink:
-Andy
