Exhaust/Turbo question, should be an easy one..
nsngarage
210
Pittsburgh, PA
Ok, im still relatively new to the supra and boost for the most part.. my question is if I buy a T4 turbo and a T4 turbo manifold, will I still need the turbo elbow or is that mostly for the CT-26 housing? and the CT-26 is considered what kind of turbo? or is the flange the same?
basically.. I would like to upgrade my turbo and exhaust system without just getting an upgraded CT turbo...
any help would be greatly appreciated..
Josh
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
A t4 described several different turbo. T4 is a flange style. You will need a t4 manifold. A t4 flaged turbo, an external wastegate and a new downpipe for this uprgade.....of course while taking care of your fuel and tuning upgrades
nsngarage
210
Pittsburgh, PA
Right, I bought an aeromotive fpr kit along with a walbro 255 pump, 550cc injectors and my lexus afm.. I was looking at some relatively inexpensive turbo's on eBay, but I wonder about the quality, even If i have to replace them before winter lol.. just to try it out and see what kinda power I can make..
the turbo I had in mind was either a .70ar or .60ar trim to4b.. just not too sure how it'll hold up... I want to start piecing my exhaust together but not until I know what the hell im doing with the turbo lol..
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
ewww ebay
good shit on getting the fuel system going before any major turbo upgrade
im running a garret t04e .60 and its great im only using the walbro and a afpr and a neo and i have tuns of fun
youll love the upgrade
frontierguy25
968
TX
What is your power goal? You can get a JT turbo or a Boss turbo from Comp Turbos for about $1100 and you can get about 500rwhp from that depending on your setup. You can still use your exhaust elbow and exhaust. If you go Full T4 you will need a new exhaust manifold, new dp, mostly custom piping for ic above the turbo, and a wastegate. It's up to you and your build.
nsngarage
210
Pittsburgh, PA
Honestly, my power goal is gonna end up in the 1k range lol.. but for now.. at least until this upcoming winter, im just doing a fresh rebuild and trying to hit maybe 350-400 i'd say..
So my parts list started out with:
FPR system
Lexus AFM
550cc Injectors
Boost controller (Manual if I run out of money lol)
Downpipe
Header
Walbro 255
I didn't really look into it much but I'm assuming a stock CT-26 can't make 400whp, so that's why I was looking at upgrading the turbo/exhaust system..
I should probably look into an SAFC tuner or something similar.. what do the MKIII peeps usually use for a/f tuning?
I really appreciate the help everyone :)
maybe I should start a build thread? lol
tbcmorris
Mar 14, 2007
1,820
I would be amazed if a stock ct26 breathed enought to produce 400+ figures
EDIT: I'm sorry I just reread and caught the can't in front of that 400....ahh 2 am a man is allowed an isnomnic induced failure in comprehension right:)
get 57trim ct26 or a sp/pt turbo. if your looking for 350-400 its going to cost more than 1k.
