Most pics will can be found here ---> Supramania Photo Gallery
Step by step build up of my mods can be found here. & price list.
Engine Specifications:
- 1JZ-GTE Single GT35/40R DBB T4 Split pulse V-band Induction 5speed 3.91 & 4.30 LSD (4.30 for drag day)
- WolfV500 ECU
- Innovative wideband standalone kit p#3781
- Aeromotive FPR
- MVP top feed fuel rail
- 750cc RC Injectors
- 3"SS Complete exhaust
- Koyo radiator
- 2JZ-GTE cooling system upgrade (15-20hp)
specificaly water housing & E-Fan(9.8amp 3000cfm perma cool)
specificaly TRD 160° thermastat aluminum hard pipe hose - 2JZ-GTE alternator (110 amps)
- Unorthadox racing under drive pully kit (20hp)
- Jaws Gear aluminum shaft (5-10hp)
- 12x24x4core FMIC
- Wallbro 255lph Fuel Pump
- No C A T (10hp)
- Releocated lightened battery, put where spare used to be(odyssy dry cell)
- Relocated/Reduced Windshield Water Reservoir
- Removed Tow Hooks
- Removed Spare tire (AAA)-member
- Removed Sound deadening barriers (55lbs)
- Removed Complete AC system
- Removed Cruise control system
- Removed Hydrofan
- Removed Progressive Power Steering
- Removed TEMS system
- Removed ABS system
- Removed Light failure ECU
- Removed Anti-theft ecu (aftermarket alarm)
- Removed Door lock ECU
- Removed Floorboard climate ducts
- Removed Gas/trunk release assembly (electric now)
- Removed Rear wipper
- Removed Rear antenna
- Tien RA spec race coilovers
- 17" CP0035 15lb WedSport wheels
- WolfV500/EFI lock out display
- Gtech RR track logger/dyno
- 2000 Celica GTS or IS300 race pedal/mod
- Defi Boost gauge
- Blue LED lighting for gauges & car interior
- Red LED lighting for gauge needles
- White LED lights for gauge warning lights
- Monster speaker wire
- Pyramid 12band EQ/AMP for IPOD audio system
- Sparco Flash 5 Steering Wheel NR»G Ver 2.5 Quick Release
- Sparco Milano Driver & Passenger Seat
- Sparco 4 point harness blue
- NRG v2 quick release hub with momo adapter
- Team Voodoo polished threaded shift knob
- IPOD audio system with a 12band AMP/EQ pusher
- 5"1/8 infintiy kapa rear 4" infinity kapa fronts
- Carbon Fiber F1 Mirrors
- Diamond Clear Corner lights
- Shaved Rear Wipper
- Shave door handles & antenna
- JDM dark amber tail lights
- Projector Lights HID
- Methernol/Water injection
- 300Z aluminum calipers & rotars
- 4 point strut bar front
- Rear tower bar
- Front lip spoiler
- Carbon Fiber Hood
- Complete Tint (VHF nite shade) Side Markers
- Complete limo window tint
A 1jzgte haves no torque at all, it's worse then a rotary.
& thats why this guy is crazy for putting it in a even heavier vehicle then our car and it cant even burn out on super swampers.http://www.rsworld.com/~nicksb/ Lol check out the videos yep its 56k MOVIE1 & MOVIE2
