Everyone Read: New rules for signatures
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
The following are the official site rules on signatures, they are guidelines to be followed, and will be enforced at the discretion of the site staff so as not to annoy other forum members.
Also a note: annoying signatures, even if they fall within these guidelines, will still result in a request for a change. This is for everyone's benefit.
  • For signatures without an image, try to keep it to approximately 10-15 lines of regular-sized text. Note that coloured text may not be correctly viewed across our multiple site styles, so it may be best to not use coloured text.
  • For signatures with only an image, keep it below 650x225 pixels and below 200KB. Also, do not use Windows Bitmap (.BMP) format.
  • For signatures with a combination of an image and text, keep the image below 650x180 pixels and below 200KB. Try to keep your text below 10 lines of regular-sized text. Also, do not use Windows Bitmap (.BMP) format images, and remember that coloured text may not show up properly across all site styles.
Thanks!
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Jeff Lange said:
Yeah, that's fine, thanks.
I'm not being a hardass or anything, it's just a friendly reminder that this site is around for everyone, not just you. :)
Not a problem :)
I try to make it a habit also to only use it once in every thread. Maybe another thing to consider....seeing the same sig 15 times in one thread can get annoying :)
