Quick tips:
Stock CT-26 = internal wastegate = SW
Reset:
1. ingition on, power off
2. “Mod” + “Alt” + “Sbc”
Learning mode:
1. car runnig, power on
2. “Alt” + “Sbc”
Inhibit:
Lock:
1. ignition on, power off
2. “Alt” + “SW<>PO”
Unlock:
2. “Sbc” + “Sw<>PO”
Auto Adjust Mode, recommended turn OFF, 'Set' will be off display
2. “Mod” + “SW<>PO”
Scramble boost setting = amount over setting. (applies to L and H)
Warning boost setting = amount over setting + high setting
Reset:
Learning mode:
2. “Alt” + “Sbc”
first pass: IMPORTANT! Do not engage boost until the car is in third gear! Begin at 2000 rpm, accelerating under boost, until an audible beep is heard.
second pass: Again, do not engage boost until third gear. Begin at 2000 rpm, accelerating under boost, until red line.
Inhibit:
Lock:
2. “Alt” + “SW<>PO”
Unlock:
2. “Sbc” + “Sw<>PO”
2. “Mod” + “SW<>PO”
