error code
tremulantX
7
Mt vernon
I was wondering about a few codes i have
i have the code 52. The knock sensor i believe, does that effect performance? whats the best way to get it to go away
and a code 12. Not sure on that one and couldnt ind any info on it.
help is greatly appreiated.
tremulantX
7
Mt vernon
Are you being serious? i posted here for help not for sarcasm.
Um the code is 12... so that is the 2nd one down? what exactly is that? and also, im sorry to ask, bt im new to imports entirely, how do i rewire the knock sensors...
tremulantX
7
Mt vernon
anything about code 12?
im gonna tackle the rewiring next weekend i think. gotta have a friend help me. you think ill need to remove my starter?
YouGotSpooled
290
Saskatoon, Sk. Canada
Not sure about removing the starter. I think if I remember correctly, on the 89+ cars you have to remove the starter. I didnt have to on my 86.5 though. Also, make sure you have a multimeter to check for continuity between the wire running to the knock sensor and the ground wire.. and I found it easiest to ground the coaxle cable under the dash.
Good luck. :icon_bigg
