So I bought a 1990 Turbo Supra w/ 180k miles on it.
When I bought it, I was getting 2 different codes.
The first was a knock sensor code. I fixed it.
The second was a code for the water temperature sensor. I fixed that as well.
Now with the car together, I am getting an error code 31.
I have done the diagnostic test on the AFM (http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&Page=96) and it passes w/ about 2700 at 70 degrees Fahrenheit. I'm pretty sure my vacuum system is good to go, as i've referenced it multiple times and done tracing.
What happens is this: The engine idles like crap, and it runs very rich. Soot is shooting out the back of the car mixed w/ condensation. If the AFM passes the diagnostic test, what else could it be?
is it possible that the engine is poorly timed causing the the code to come up because the engine can't adjust the timing properly? (Say one of the cams was put in improperly?)
I've read a few articles about 31 and I don't feel any of them are like this.
Thanks,
Martin
Thanks,
Martin
