MDCmotorsports said:
And fluids out of the pan?
MCD - Take a look at Bama's previous thread:
http://www.supramania.com/forums/showthread.php?t=19533
The pics show the condition of the car when he got it.
Bama - If you asking should you pull the block or not...I'd pull the block out of the car just to paint over that god awful color :aigo:
Seriously though, what MCD is trying to get across is if there was
any water intrusion in the pan, cylinders, etc the block is fubar. Pull it, look for signs of water damage, check the bearing clearances with a flex gauge. Otherwise you are taking a chance with a motor you really know nothing about. The 7M will develop rod knock in a heartbeat with contaimated oil or worn bearings.
I grew up in AL...with the humidity the way it is there, that motor would be on a stand with me going over it with a fine tooth comb. And I'd paint the block...lol.
But, it's your motor...might work for you to leave it as is...or you may have to learn the hard way like a lot of us here have
