So i may be picking up another mk3 however the engine wont crank.
the seller was able to jump start it, and it started fine Once. but after that it would not start anymore.
If you were to try and crank it everything would go dim as if power was being drawn from the battery to try and start.
i did bring the battery to oreilly to get it recharged and tried it, and still wouldnt start
The car has a viper 5901 alarm
its an 86.5 with sunroof, originally 7mge automatic
but has a 7mgte and r154 swapped in..
Any help is appreciated. Thanks
