Engine Update, Pics No 56k
NJSUPRA
NJ
Well I finally got her runnin. turned out I had a bad afm elec. Its been a long road but i finally got to take a drive today. ANyway here is some pics i took.
DONT mind the loose wires by the thermostat housing, and need to finish looming the other wires too, , i was lazy and took pics anyway.. :)
The new i/c and pipes were courtesy of quikstrike. all aluminum pipes with 2.75 uppers and 2.50 lowers. the i/c is 24x12x3 bar and plate. I know that intake filter is pretty damn small, but its the only thing that would fit. i guess ill just see how it works out
This motor started as a jdm that i bought specifially for rebuilding. 6m crank. head is rebuilt to stock specs.
- ross pistons stock bore @ .005 gap
- tms 2.0 mm mhg
- Arp Head Studs, Main studs, and Rod bolts
- New Toyota main and rod bearings, oem oil pump
- sp61gt bolt on turbo
- ported exh. mani
- BIC dp/elbow combo
- BLitz Nur cat back
- aero afpr / 550's / Lex / Safc2 / walbro 255
- J - tube, and fpd removed
- Spec stage 3 clutch
etc..
Here is some older pics of my progress throught this rebuild
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
:yumyum: looks good congrats on getting her running. i myself just managed to get mine on the road today after staing in the garage until 2 am last night finishing up. enjoy the motor and i hope it dosent fall apart on ya!
mkIIIman089
Ohio
Where in Jersey are you? Probably more south then I am able to travel, but I'd figure I'd ask anyway. Looks really good though man! congrats.
Z
ztosupra
Guest
That engine looks like a beast. Let us know what it puts out when ya get it tuned
