engine thumping
gamer565
30
KS
i have a N/A 87 3.0l v6 and the engine is making a thumping sound(like something is hitting against something)
any ideals?
Supracentral
10
That's called a blown engine.
Rods, bearings, something in the reciprocating mass is screwed. No matter what it is, you need to pull the engine and examine the internals.
Kckazdude
1,239
Memphis, TN
any ideals?
If this is a Supra the problem is in red.
*Ninja edit*
Should have refreshed after phone call.
87mgte
87 Turbo Targa
Sep 9, 2007
536
Sequim
any ideals?
:slap:
It's probably rod knock.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
any ideals?
You are not joking right?? But yea, from what u are telling us it seems like it is rodknock you are talking about...and it is about to blow.
Tun_x
Built to do the NASTY!!
Utah
Hold it at 6000 rpm until the failed part falls out on the ground ... saves disassembly time:biglaugh: and simplifies diagnosis
AJ'S 88NA
2,419
Florida
suprarx7nut;950838 said:
I can see another supra meeting its grave soon...
Come on guys a little "thumping" doesn't hunt anybody now and then.:)
I think he's got more problems than rod knock if it's "thumping" instead of "tapping"
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
" i just bought it off of craiglist for $4,500 "
or
" i work at a pawn shop and i want to sell it "
Halsupramk3
444
Mississippi
simplest ting to check before you pull the engine is to make sure the harmonic balancer bolt is tight. if it backs out a litttle the pulley will wobble at lower rpms especially and it will sound like a low frequency thump. get under the car and crank it down to 195 FTlbs. if it has been loose too long it will damage the snout of the crank and it will just pretty much wobble all the time even when the 7m bolt is tight. if your bolt is backing out it may be best to buy a new one. if you have to rebuild do get a shop to inspect your cranck snout and balancer to make sure it is a snug fit.
gamer565
30
KS
i think its rod knock(but the engine only have 155k miles). when the car is running if u put ur head under the car or low to the ground u can really hear something hitting the oil pan or something in that area.
