Ok, so for those of you that don't already know I bought my Supra for $1600 with a hole in the block. Its an 87 Turbo, with a built head, and some "custom" (hack-job) wiring. I'm working on removal right now. I have a service manual that gives good general info, but can be vague at times because it covers 79-93 Supras, so basically Mk II and Mk III. I'm a second year automotive student so I have some experience and I know basics like use masking tape to label wires, vacuum lines, bolts, take lots of pictures, etc. I was just wondering if anybody had some advice that might be able to help me with this specific application, any tricks or experiences learned while doing a swap of your own that aren't in the manual will help. So far everything seems pretty straight forward, but the more you know the better. I'll continue to update this as I have questions. Thanks in advance for any input.
UPDATE:
So I have 2 major questions that have formed in my mind.
Acessories: Is it easier to pull the motor with the alternator and power steering pumps attached, or am I better off to remove them?
Transmission: I have seen two procedures, both in different manuals, one says to pull the engine and trans out together, the other says to leave it in. Which way would be easier? I don't have a lift though, so I have to go out the top though, so keep that in mind.
Thanks for your time and help, and I'll be sure to give a full write up and pics when this is done so I can help others that run into the problems I have along the way.
-AM3
UPDATE:
-AM3
