Engine struggles after Lexus AFM/550cc mod.
artorush
Oslo
Installed the 550c injectors and Lexus AFM today (took my time with them). When I turned on the engine it struggles to stay on, the RPM needle would fluctuate, then engine dies. The only way for me to keep it running is to rev it up, but once I stop revving it'd struggle and dies.
Every hoses, connections, injectors and seems fine.
I've checked for error codes from the ECU. There is some code. But I can't quit understand how to read this code. When I start the engine it blink first 2times....then....4times....then....1times....then...3times. It goes on and on like this.
I really need this car to be running normal again, I am stuck with out it. :icon_conf
Any advice would be thankful.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
That would be codes 24 and 13. But, that doesn't make sense to me, as I thought it started with the lower numbers, and moved up to the bigger numbers. Correct would be 13 then 24. I'm sure someone has the link saved to tell you what those are.
artorush
Oslo
Yes I do have link to those codes. It's here. But can't it really be one of those codes? Do it make sense after this mod? Anyone?
DBN
FML
Jan 22, 2009
247
Fairfield, Ca
My car sometimes does this when i have a code 32. I've checked over the numbers the OP posted and just like ForcedTorque said it cant read the codes from highest to lowest. Im thinking that you might have caught it in the middle and you may actually have codes 32 and 41. Not exactly saying that you did it wrong but its a possibility. Hope this helps.
artorush
Oslo
Yes I did connect it to the AFM, but I don't go all the way in, I will try to push I futher inn. 32 and 41 can some more likely to, I going to check those tomorrow. Thanks alot for the replies. I will tell how it went tomorrow.
artorush
Oslo
OK, I've check the intake air temp sensor signal in the air flow meter(CODE:24). It is all fine, I've tested it with an ohmmeter. I've checked also the voltage on the ECU(THA - E2) 4-5V on ignition on, and the wiring, no problems there.
Started to think it must be else were. Maybe when I switched for the new injectors, and I had to change new plugs because the ones wouldn't fit. So there can a injector wiring is short circuit, and a piston rod are not working at all. I just tried to remove one injector plug while the engine was running, it sounded and preformed worse. Can this be the cause of it????
artorush
Oslo
RiyadYar;1325419 said:
did you put the 7m electronics on the lex afm body
I tried with both same problem. Where do I find the HAC sensor signal on the 7m-gte? Reading from Code: 32.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
do you have a afpr? if you do what is the fuel pressure set to?
if i remember right the lex/550 run insanely rich on most cars so you have to drop the base fuel pressure down a bit for it to even idle. you will look like a diesel if you leave the base stock. i'm guessing you don't have a WB so check a plug and see if its black(running rich). a WB is something that you really need if running over fuel cut. i have a uego that i really like.
artorush
Oslo
No I don't have any afpr, just lex/550. It do smoke a lot of white smoke, and the it forms a black dirt line on the ground. Too much fuel?? No I don't have WB. So I should check the spark plugs if their black? If so I'm running Rich?
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
^yup. you only really need to check one plug. i would go for 6 since you can just pop the wire off then pull the plug.
the white smoke thing is a different story. does it happen even when the car is warmed up. are you loosing coolent post a vid of the smoke if your worried.
artorush
Oslo
Ok i'll check that one. I am not sure, i'll check that now. I will post a vid also.
artorush
Oslo
Yes it does run rich galore! I've checked what you told me, the sparks plugs are black. Is it any way to clean them or do I have to buy new ones?
I also checked the coolant, the level has dropped a little on the coolant reservoir(I've not been driving since the mod yesterday, just cracking the engine). I took some pictures which seems like a leakage from some were.
In the video I couldn't reach any higher rpm as you see, no matter how hard I pushed the pedal. Seems very subnormal. And the engine struggles like hell. And you can see white smoke coming out of the exhaust adding a black layer on the ground. Can it be because not all the fuel getting burned efficiency or the coolant geting mixed in the explosion chamber?? The engine died at the end of the video.
(Sorry for bad video quality).
VIDEO
Any advice would be helpful.
8,897
if i remember right the lex/550 run insanely rich on most cars .
No it doesn't. It runs insanely rich on any car where the owner cranked the screw, installed a pump, and didn't bypass the j-tube. It won't run any richer with the larger meter and appropriate injectors.
Supracentral
10
Nick is correct. The 550 cc/min injectors are 25% larger. The Lexus AFM is 25% larger. This is the entire point of the Lexus/555 mod - the car should run nearly stock provided nothing else has been changed.
Sounds like a wiring problem. Check the connector on the AFM and the harness. Make sure you didn't bend up the pins or push a connector out.
RiyadYar
384
NY
yea i would check make sure none of the wires insulator got ripped off ,,,also did you clean the electronics before you swapped them because iirc your not supposed to clean those with any old cleaner ?
artorush
Oslo
Problem solved. Working like a charm now. The was two errors: First the afm, switched to another and fixed the connector. Second: There was a major exhaust leakage from the exhaust manifold, I needed just to tighten the bolts. And there is absolutely no need for any afpr, so that is just bullshit using money and time on that. And exhaust temp readings are normal. Thanks a lot for the replies!
grimreaper
2,180
Dallas
an afpr should be your next mod if you have more lined up. You need SOME control over whats going on (even if its basic). Check your vf's. What are your WOT af ratios? If its remotely close to mine your in the mid 9's af ratio wise at wot with stock fuel pressure settings.
