Engine Stand Bolts
Lupe120
The Boot
I'm getting ready to rebuild a 7mge, but don't have any bolts for the engine stand. From what I understand not all engine stands will require a longer set than the ones that are in the car, but I'd rather be safe and have an extra set. All of my searches on google come up with bulk purchases, I only need 4. Does anyone have a link to a website that I could purchase these bolts from?
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Hardware store they are just m12x1.25 bolts.
Stock headbolts work great if you have a set laying around.
Suprapowaz!(2)
2,870
San Antonio, Tx.
If you get longer bolts then have washer available just in case you need them.
My stock bolts wouldn't work on the engine stand. I had to get longer bolts. I needed washers to fill the gaps.
Asterix
Lurker of Power
Vienna, VA
The correct bolt size is M10-1.25. The bolts may have 12mm heads (flat-to-flat), but the bolt shank diameter is 10mm. The thread pitch is 1.25mm. My stand requires long bolts, 90mm long; yours may differ.
McMaster-Carr is a great source for bolts in small quantities.
