Engine stalls after Acceleration?? New iacv
Zrain25
639
Pelham,New Hampshire
I have had Idle issues since I have bought the car 2 months ago it would start cold at 500 rpms the. Work it's way up to 1100 rpms. I adjusted the tsps to spec and cleaned the IAC. No luck . Got a good used IAC put it In starts at 1300 rpms cold idles at round 750 warm. That's all good I hop in go for a spin around the block give it some gas go to shift to 3rd at about 2500 rpms. I let off the gas and hit the clutch and it stalls. I start it back up do the same thing in first gear rpms drop to 300 when I let of the gas past 2000 rpms and it dies. I can keep it going if I give it some gas with the clutch in while shifting. It never did this before. The idle is good now
My bov is vent to atmosphere but it has never made the car die. I have a Recirculation kit coming in?
I have no idea what could be wrong. Car I's going in for paint next week I need to fix it
Any idea thanks?
radiod
1,342
Abbotsford, BC
I'd test it with the BOV recirculated personally first. I had stalling issues between shifts like that when my recirculation was LEAKING, not to mention not there at all. Beyond that double check all the vacuum lines and make sure they're all secure and none are torn or leaking. Check your intercooler piping/couplers and make sure those are in good order as well.
