engine shuts off in second gear
hotpapi17
hinesville
hey i have a problem and would like some help if u dont mine the engine is completly stock when i drive it sounds like a robot jacking off sort of like if it were lifters. u only hear it when u accelerate though not when u shift down.. just seeing mainly if i can fix the engine from shutting off in second gear and it only does it in second gear lets say i floor it i go into second and then around 4 or 5 grand lets say i let off it will shut down but ignition still on thats what i run into.... if i drive soft or downshift soft it wont do it. and the sound i feel it in the pedal not too much but u hear it when idling and as rpms go up the sound speeds up with the rpm the, sounds like lifters or the best sound is as if it needed oil u know when a car needs oil that click click sound the oil is the specified manufactor oil and its synthetic. by the way its a supposively a 40-60k engine
Welcome to supramania papi. This should be in the technical section and not in the introductions or in the visitor messages.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
sounds like you might be missfiring/running lean...check your compression/ignition system and fuel delivery.pull a plug and take a pic.
will it shut off in 3/4/5th gear also?
