Okay so guys I have a bad HG and im going to be replacing that with a MHG and arp studs.I am also getting the block machined and laped. I will be getting some seals replaced and a new water pump. Other than that what shoud I do while Im in there. I also would like to know what internals could I get since the engine will be out. Any ideas or info. will be great. The max I can spend is 5,000 I only want to spend 4,000 at the max. And I only plan on running 400hp max in the future.
Thanks,
Josh
Thanks,
Josh
