Well im going to use eagle rods and ARP rod bolts. Im going with .40 over JE pistons. A 2mm cometic head gasket and ARP bolts, and all the necessary maching work of course. Im in the process of disassembling my engine right now. Once I get it down to the bare block I have to have it boiled and magnafluxed to see if it has any cracks or flaws. If it does ill just have to buy another one from somewhere. All clevite bearings. Regular things like new water pump, oil pump, thermostat. T61 turbo. 550 Rc injectors with a MKIV fuel pump and walbro regulator. As for management I think im going to go with the maft pro with the boost control solenoid a wide band. Although I have not decided on the wideband yet. Stock crank and stock head. Although if I have the money I will have the engine blueprinted and balanced. This doesnt really have anything to do with my engine but im also have a fidanza flywheel I have to install and I might as well upgrade the clutch as long as the engine and tranny are out. For track days (or whenever I am losing) im going to install a modest 50-75 shot wet nitrous system. Thank to some people on the forum who have pointed me in the right direction to some good information on FFIMs I will also eventually make one of these up to go with my intercooler(if I ever get the time from work). Well thats about it. Suggestions and criticisms/comments would be appreciated.
