I recently got my mkii 7mgte running again after redoing the engine bay. The engine has a new engine harness, To4Z turbo, FFIM, 720cc injectors, AFPR, Aeromotive A1000 fuel pump, and is running the MAPECU. Now the engine starts right up and idle solid. It will rev up fine and sounds very strong at idle. However, once you apply load and try to drive the car, the engine will rev to about 2-3k then just let off. If you hold the gas constant at say, 25% throttle, the engine will rev up then just let off like you hit fuel cut, then just rev up again and continue the cycle. There is also no check engine light on. Does anyone have any clue what could be causing this?
As far as the MAPECU, it seems to be working fine. All the readings, such as TPS percentages, RPMs, and A/F ratios seem to be working fine. If you make adjustments to the fuel the A/f ratios do change which leads me to believe that its working ok. Any ideas??
