Well, first of all I have rod knock and wanted to know why it is so common on the 7M motors? Is it something we cause? Also I was reading Grim's engine overhaul post, (nicely done btw) you dont unbolt the bellhousing, you just take the tranny out with the engine? I have always unbolted the bellhousing but I guess the top bolts would be impossible to get to?? And im going to switch the distributor or whatever you call the electronic one how do you set timing when you put the new one in? I have done normal ones where you get #1 cyl to the top of the stroke, put it in with the rotor facing a certin point but how does this electronic thingy work???
