Engine Mounts for 2jz
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Hi guys,
those of you who have a 2jz in a MKIII, which year mounts did you use and why? I heard 93 - 95 is different from the newer ones. will either work ?
I have a 92 and 1jz brackets.
Thanks.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I've read somewhere that you just have to grind off the bottom alignment nipple. I've also read the 96-98 are better mounts than the 93-95.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Use the 1jz mounts, i believe that's what you need, feel free to correct me if i am wrong, thank you.
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
moe, you want the 98 twin turbo mounts from the mk4, it looks dam identical to the 1j late 7m ones, but it won't break..... there's just a nipple you have to cut off so it will sit flush with the crossmember thats what i did when my gay o 1j mounts broke i replaced em with 98 ones, you can buy the 1j ones, if you want em to break :biglaugh:
the 93-95, are totally different then from the 96-98 i believe, all i know is that they are both different cause i seen it and looks like there's no way in hell it will fit in a mk3 for sure, unless 96-98
joey_daze
KILL UR CORPORATE MASTERS
Apr 6, 2005
72
Tung Chung, Hong Kong
:werd:
