engine missing
turbotrev
Goin WEEEEE on my gsxr600
Aug 7, 2006
311
Clinton, MO
ok my friend has a 89 n/a auto and he has just replaced a bhg and its missing bad ive checked all the injector plugs, coil packs, and all the connections
so what could it be.... could it be a fouled injector, bad plug(he got all new ones and wires too), or bhg again not even 600 miles on it yet???:1zhelp:
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
You'll have to treat it like a brand new problem, and start with spark at each cylinder, then move on to fuel at each cylinder, until you've found the cylinder(s) to blame.
Vacuum leaks can cause it. Do you know how to check all the hoses???
If they are hooked up to the wrong port, you may have a leak but not find it.
and how to use a propane bottle (camping size) to find vacuum leaks??
yankiwi
221
DFW
Did you look here?
OH NOES...................It IS missing:aigo:
turbotrev
Aug 7, 2006
311
Clinton, MO
<haha on> IJ <haha off> :biglaugh: and yankiwi yes you ass lol:biglaugh:
mrnickleye yes on the checking of the vac lines and no on the propane bottle
and thinks for the info on the restarting of the whole process to find it
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
easy there, killer, or IJ will smite your ass. just search around and [hint]look at his damn post count[/hint] you should be able to find the solution. if not, break it down piece by piece. itll be tedious, but that's all we'd be able to do, given the information you handed to us.
mrnickleye
Jun 8, 2005
825
Mojave Desert, Ca
At the shop, we use one of those camping propane bottles, and a little valve that has a botton on it to squirt some gas, and a rubber hose. With the engine idling, we take the hose and squirt gas along the intake gaskets, and throttlebody, etc.
Don't hold the botton on too long, as too much gas can kill you. BOOM !
If there is a vacuum leak, the engine will smooth out when the propane gets sucked in. BINGO !!
Clip
Oct 16, 2005
2,738
9
Virginia
is there any way to put seniority on here? on the angelowners forum, we used to have something in the top right corner of every post showing the member number. somethin like the order we'd signed up, i think.
my bad, trev. you gotten any farther with that engine?
mrnickleye
Jun 8, 2005
825
Mojave Desert, Ca
Look to the left of every post, at who posted. see the join date. thats the seniority here.
turbotrev
Aug 7, 2006
311
Clinton, MO
went through all of the stuff again and its still missing and sputtering like crazy
but o well i think hes goin to ether turbo it or build it but i dunno hes a little retarded school b**** anywho
