I have a built 7MGTE ( check signature for mods ). It is currently running 18psi. I have two problems.
1. Very hard to start when cold. After it warms up it starts easily.
Battery is good ( as per Autozone )
2. When car is cold it runs perfect. After it warms up there seems to be a miss, and hesitation.
Plugs are +1 heat range from stock
AFR reads 13-15.5 at idle
same for light throttle
10-11 on WOT
the miss bumps all readings up to either off the charts or very close to it. Then they drop back down.
I am picking up a COP mod from a member on here once he checks his PMs. So that will be added. I figured it has something to do with my ignition so I am checking on that first mainly because I want that mod done anyway. Any ideas would be GREAT!
10-11 on WOT
