So I just took my 88 turbo to the dyno about two weeks ago. Before I took the car I changed the oil using 6 quarts of castrol full synthetic. Over the last two weeks I noticed that the car was blowing white smoke at cold start and also under high boost. I thought that it could be the turbo seals going bad or maybe it could be burning oil. It also has a small oil leak.
I took the car for a spin yesterday and got on it on the highway. As I got a block away from my house I heard a rattling noise. I pulled into my driveway and shut the engine off and checked my oil. It was 2 quarts low on oil. I don't think that it was leaking this much oil in such a short period of time. Went up to autozone bought two quarts of oil and put into the car when I got home. It rattled when I started it and then smoothed out. At idle it does not make any noise at all. If I push the accelerator hard up to about 4K or slowly push the accelerator it will make the rattling noise as well. It sounds like its coming more from up top then anything. Do you guys have any idea's? Thanks
