Engine inquiry (pic)
Donedreamin
Toronto
Hey , i just want to confirm what these two inputs (sensors) are on the block.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
1) knock sensors.. green clip in the pic hanging up by the grounds on the intake manifold
2) looks like a wire comming off the thermostat housing lost a plug. I may have to bust out the TEWD and look up the wire color.
Donedreamin
Toronto
I'm currently throwing in a 7MGTE into a cressida, without the knock sensor hooked up it runs. What can occur besides bad gas mileage , etc.
Is it crucial to have plugged in ?
Thanks alot for the responses, means alot
shaeff
Kurt is FTMFW x2!!!!
10
Around
Yes. Leaving the knock sensors unplugged will result in timing retard, bad fuel mileage, and enriched fuel mixture.
Two lower red circles = knock sensors. The uppermost red circle = knock sensor connector (there should be two of these)
Blue circle is a block heater that's installed in place of a freeze plug, as Poodles stated. The connector for that is not likely to be incorporated into your engine harness.
Donedreamin
Toronto
This forum is very helpful , much appreciated.
One problem is , unfortunately i don't have access to the car right now as its a couple hours away in storage.
But it's quite clear there is not a plug-in for the forward facing knock sensor.
The verdict is i need to purchase a new unit?
