I'm currently restoring my engine wiring harness. I've looked through the forums and found this website: http://easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SM-MT/sm-mt.html
For my broken connectors I can buy the new ones from that site. I have a few connectors that are in good condition and I would just like to re-pin them with new terminals. I took the pins out of a few connectors and am comparing sizes. Does anyone know of a chart where I could find what size terminals would fit each connector? Or if anyone has re-pinned connectors before, what size terminal did you use and where can I purchase it? Here's some information I found:
I could purchase the 090 terminals from that website, but I still want to re-pin other connectors, and from taking my harness apart I can see there are many different size pins. Thanks in advance for any help.
there are certain plugs which do not use the sumitomo MT-style 090 pins including many of the temp sensors, the O2 sensor, oil pressure, AFM and TPS (last two not 100% though). I haven't looked into these plugs so I have no idea what style terminals they use. As far as de-pinning goes, a precision screwdriver set is all that I needed to disassemble the plugs.
Plugs such as the coil pack, cps, igniter, transmission, injectors, vsvs, and abs all use the MT-style 090 terminals (pins).
