I have a pretty bad problem.
I currently have a 1988 Supra turbo automatic and just had my entire engine and trans rebuilt / upgraded. My engine harness that I was using is shot. It is missing connectors, the wire is brittle, and you can hear it breaking if you bend it slightly etc. I was planning on getting a new harness but found out that the 88-89 auto ones were discontinued. My mechanic that is working on my car has been in touch with Toyota and has been told different stories about being able to get one from Japan, that they have one on the way, or that they were not sure. I have been waiting on it for at least 3-4 weeks now without much on a positive outlook. I just found out that Toyota does have the 90 and newer engine harnesses in stock for the auto.
My question is would a 90 auto 7mgte harness work on an 88 auto 7mgte? I understand that it might need to be slightly modified and such but would be better to cut and crimp / solder different connections in certain spots than to try and use my old garbage harness.
If it wont work then what would be the best way for me to get my car back up and running?
Thanks in advance,
Kevin
Thanks in advance,
Kevin
