ok ill put my dilema out first. i have an 87t 5sp and just bought a jdm 89+ 7mgte replacement motor. swapped out the sensors so i just need to do the connector swaps on the harness. the harness that came with the 87 was pretty beat up so i bought an 88t 5sp, same harness right? well when i got the harness the connectos going to the ecu are gray, and i know i need a harness with yellow connectors to the ecu.
im wondering if i can still make this harness work with the 87 ecu. i know the hac or whatever is internal for the 89+ ecu and is external for the pre 89's. can i make this harness work? can i swap out the gray connectors for the yellow ones? or do i need to get a new harness? any help will be greatly appreciated
