Engine harness plastic mounting tabs
OneJoeZee
Retired Post Whore
aboard the Argama
I need couple mounting tabs for my harness. You know, the one's that push into the firewall to hold the harness in place. Can you get these from a normal hardware store or maybe the Toyota dealer?
Or does anyone have an alternative method they used to secure their harness to the firewall?
Thanks in advance. :)
-Joe
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
The clamp style with the latching push pin? I've seen them in specialty hardware stores (mom and pop owned Ace and TruValue). I don't think Home Depot or Lowes carry anything like the stock plastic clamps, but they do carry rubber coated meat straps with a bolt hole. You could use one of those and get a package of 1/4" plastic push fasteners.
McMaster-Carr has some that'll work for replacing the majority of our wire harness clamps. Go to http://www.mcmaster.com/ and search for "cable mounts".
DigiKey also carries alot of fasteners, but they're easiest to find the right one if you've got their printed catalog. www.digikey.com
I actually think DigiKey's probably got the best selection, but minimum orders may be an issue with some parts.
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
you can get them from toyota , you just need to determine which ones from a newer toyota would work (mid 90's camry and up ?!?) and order some. the dealer has a chart at the end of each wiring section on the epc that shows you the radius/diameter of the holders.
or.....
....junkyard scrounging!
