Engine comes out this weekend - advice please
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
I have read all the threads and gone through the tsrm and walkthroughs. Now the question:
Do you like to pull the engine out with the harness still on or leave it in the vehicle and why?
Thanks in advance
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
unplug it from the ecu, pull it through the firewall and lay it over the top of the engine. Piece of cake. I learned the hard way the first 7M of 3 that I've pulled.
EDIT: Matt is quicker than me apparently
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
1000x easier to unhook the harness from the ecu and leave attached to the engine.
My first supra which was a MKII didn't do it this way and what a pain, I have pulled probably 10 supra engine since and would do it no other way.
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
Thanks for info gentleman. It is much appreciated. I'll get crackin' Friday night and hopefully have it on the stand by Saturday afternoon. :x:
jdub
Feb 10, 2006
10,730
Valley of the Sun
When you start to lift the motor out, make sure you do a check for what you forgot to disconnect ;)
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
So I take it if you are doing an NA-T conversion, it would be easiest to unplug it, pull it w/ the engine, and swap harness's plug by plug and then label all of them accordingly so its a piece of cake when replugging it all back in after a rebuild?
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
I hear the harness going over the trans (or to the trans) is usually the one that gets ya.(probably at 1am after too many mountain dews:icon_bigg )
Any other common points of "oops" to watch for?
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
If you're pulling the tranny at the same time, then don't worry about it. If you aren't, mine was cut by the p/o right below the egr and installed a connector. Much easier that way.
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
drain your tranny, i hate cleaning up the floor from tranny grease/fluid. and those grounds dont forget those i always forget 1 every time.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Yes, always check to any grounds still attached to the chasis right before you think you're ready to pull it out. Take lots of picures so you don't forget where something goes!
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
Yup tranny coming with it. Might as well check out the clutch and throw in some seals.
You bet. All the fluids are getting drained and replaced while she is down.
Once again I would like to thank everybody for their input, it is a big help and much appreciated.:wavey:
