Engine bay clutter?
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
I am looking to clean up the engine bay a bit and its just got all this stuff looking like a big mess. What are some things I can do to get rid of some cluter such as the charcoal canister, vacum lines, anything worth getting rid of?
8,894
Why not get rid of the intake manifold? That takes up a lot of space. So does the CPS and wiring. Throw them in the garbage too.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Heck...what about that nasty looking coil pack on top of the motor!
:3d_frown:
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
Here is my attempt at a little clean up.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
you can move the fuel pump resistor and relay next to the passnger fuse block instead of under the hood get rid of AC lines condesnor
go from hydro fan to electric fan
get rid of cruise
get rid of abs
co2 canistor evap crap
reduce vacume line system
relocate battery to spare tire hole in back of car
get rid of the windshield cleaner system put a simple little bottle next to the brake booster instead
get rid of hood latch and bracket use hood pins instead
look around in there if it dont seem right and usefull or stands out try to move it.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
That's why I'm gonna get Ron's manifold. As for the coil packs how can I move them somewhere else?
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
You can. You have to make custom wires. I've seen them moved to alot of diffrent places. My fav. is in this pic.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
That is just beautiul, so I can mount the coil packs on the fire wall and get some custom wires?
BoostedFloto
154
Tampa, FL
That pic is my engine bay.
The coil pack was pretty easy to move just made up some brackets. As far as wires go, I bought the car with a set of MSD wires on it already and then bought another Set and mixed matched the correct lengths.
