I am trying to figure out what goes in these plugs. Can someone help me figure out what goes where. Also there are 2 thick black wires that have been cut. Dunno what those are. And the stupidest ? of all. How do I tension the serpintine belt.
Freshmaker said:Well seems like you got your plugs figured out, as for your belt, it uses a spring tensioner. The center pulley is mounted on a lever with a spring. Once you get the belt on there, it does the job for you![]()
pocketrocket07 said:Put the Belt on the pulleys then throw a 14mm (i think) rachet on the tensioner bolt and push down and it will then tension up.
