ok so i did a search but didnt really find what i was looking for...
i cant pass emissions to save my life!!! i have failed 4 times now...
1st time i should have known cause i was running the 680cc injectors with no management on a stock 1jz ecu, i failed HC and CO but passed NOX
2nd time i swapped injectors to the 440s and adjusted the fuel pressure, failed NOX but passed HC and CO..... HC 53/ allowed 111 CO .01/ allowed .61 NOX 1255/ allowed 773
3rd try i adjusted exhaust timing(retarded to -5) and fuel pressure and failed everything.... forgot to get copy of inspection
4th try i adjusted exhaust timing (retarded to -2) and am back at failing HC and CO but passing NOX..... HC 285/ allowed 111 CO 6.66/ .61 allowed NOX 316/ allowed 773
and they arent just like a lil out, its crazy off... what should i do?? i dont wanna keep giving $25 away to fail again
car setup- 1.5jz with gt40-82 3.5in exhaust turbo back, 440cc JDM injectors, new cat, fuel pressure set at 32psi at idle, plugs gapped to .025, exhaust cam set at retard -2
chris
chris
