First test. i'll be doing a retest here in a few days.
all the numbers are in ppm
HC
199 max Mine:827 @ 15mph
184 max Mine:865 @ 25mph
CO
0.82 max Mine: 12.44 @ 15mph
0.72 max Mine: 12.46 @ 25mph
NO
1949 max Mine: 480 @ 15mph
1749 max Mine: 537 @ 25mph
Mods:
Hi flow cat, 750 injectors, 60-1 turbo (not in boost during test), 255 walbro, stage 2 crower cams (Adv. Dur.: 264264br>Dur @ .050: 220220br>Lift (in): .336"/.336" Lift (mm): 8.53/8.53), maft pro to tune, wideband o2.
the plugs are new, wires are magnecor, timing is advanced 2 degrees. The car past last year with the same mods other than the cams. I have not fully tuned the car with the new cams (at least down low). with the cams installed, i am running pig rich (down low) on my wideband. I am guessing that if i just tune out the car i should pass???
i'll keep you all posted on what happens
