emanage
Justin
Speakers?
Spokane, Wa
1:
When no maps are initilized the car runs fine, however, when I go and hit load, it brings up all the maps, even though I only selected timing, and airflow. after that, the light on the emanage itself starts flashing green/red/green red... code 11, AFM problem, and the car won't rev...
when i clear all maps the code goes away and the car rev's fine.
what the problem is?
2:
I also noticed in the airflow map i only have the 'Y' numbers, no 'X' numbers... its just blank... I have Greddy PR SENSOR selected in the PARAMTER screen.
3:
http://www.mohdparts.com/emanage/ma...1_manual/43.jpg in the AIRFLOW CHANGE box, which do I set it to, 1, or 2?
Bishop92t
773
USA
www.ma70.com
1 What firmware are you running?
2 Are you trying to change values based on throttle or pressure?
3 MT_KR-2 should be the "AFM" you're using. There shouldn't be an actual AFM change, just MT_KR-2.
Justin
Speakers?
Spokane, Wa
1.
Display Unit - 1.13
Center Unit - 1.11
Emanage - 1.42
2.
Pressure. I had initilized the emanage to clear the code 11, which had reset a few things. The one thing I noticed was that the throttle position wasn't working, so I went and confirmed that and then the RPM's came back to the map. X = Boost, Y = RPM.
3.
After getting everything reset I managed to get the Air Flow adjustment map up and running with no erros... not sure why the errors were coming up in the first place:dunno:
Bishop92t
773
USA
www.ma70.com
On some of the cars I've tuned/installed e-Manage's into I've noticed the blinking X column and they seem to be TPS related. I don't run any of my maps boost related except ignition, and most of the installs I've done were purely throttle based.
Justin
Speakers?
Spokane, Wa
dr. j recomended that I do it boost vs. rpm, so I figured i'd give that a shot... Can't really hurt anything as long as I keep an eye on my ZT2
any idea why i might have been having that issue with it not being able to rev, and having the code 11?
