Emanage e-01 and Zeitronix
josh930
247
NY
I have done alot of research and still am a little confused on the subject. Are you able to datalog A/F from the zeitronix to the e-01? I know there is a feature in the e-01 to covert a voltage signal (1.75v) to the correct a/f ratio (12.5:1). I have read the info on here http://drizze99.conforums3.com/index.cgi?board=hardware&num=1108992978&action=display&start=0 but I'm not sure what wires to hook up in order for the e-01 to datalog the a/f from the zeitronix or if its even possible. Thanks
Bishop92t
773
USA
www.ma70.com
Yes, you need the "external harness" for the e-01. Hook up the e-01's white or gray wire to the 5v signal from your Zeitronix and hookup the e-01's black wire to ground. Set the e-01 via http://www.mohdparts.com/emanage/manuals/profec_e-01_manual/24.jpg If you used the white wire it's channel 1, gray wire is channel 2.
