Hey,
This question is mostly targeted towards NA-T people with GTE electronics. Although it is rather unique, if you know about simple electrical currents I'd appreciate your help.
I have been throwing a code 52, short in knock sensor circuit, for some time now. I have replaced everything- new shielded wiring up to ECU, new clips and connectors, and finally a new $157 knock sensor.
The thing is, I'm NA-T with GTE electronics, meaning I have to run the two knock sensor inputs to the ECU to the single knock sensor (other knock sensor holes where turbo KS's are usually are not pre-drilled).
My car ran fine without codes for about 6 months by just splicing the 2 stock KS wires together right before the single knock sensor and plugging it in there. When it started throwing the code, I thought it might just be the old wires so I replaced that, and then the clips, and now the new KS.
I was reading up on the internals of the KS with it's vibrating crystal to make a AC voltage and noticed it runs through a resistor inside the KS. Do you think that since I only have half the resistance that the turbo ECU is used to, it throws the code?
That hypothesis would not explain the fact that it ran fine for 6 months. The resistance of the stock wires and the new wires was determined to be almost non-existential so one can not say that some resistance came from the old corroded wires to make up for the missing resistor.
Thanks alot,
Alex
Thanks alot,
Alex
