Electrical Question
spudz29212MKIII
Columbia, SC
Okay, So the spoiler along with the third brake light were removed from my 87 by the previous owner. My question is: what do I do to get rid of the taillight failure light on the dash? It will only come on and stay on the first time I hit the brake pedal after starting up. Is there some way to fool the computer or wire the connection so i can get rid of the warning light? I am no electrician but, would you ground it? short it out? or what?
Thanks for the help.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Welcome to SM. You have 6 choices:
1) Defeat the box (remove and bypass it).
2) Open it up and recalibrate for the missing lamp (done with a resistor change).
3) Put a CHMSL back on, either with or without the spoiler.
4) Connect a lamp and let it hang somewhere.
5) Connect a (big) resistor across the wires and let it hang somewhere.
6) Disconnect, remove, or tape over the dash indicator.
I recommend solution number 2. Number 3 is also OK. The others are generally done by those unable or unwilling to fix things right. If you're one you'll find plenty of company here...
rayall01
901
Westfield, ma
One other option is to install the third brake light from a NA supra, one that has no wing. I think legally, you have to replace it anyway.
spudz29212MKIII
Columbia, SC
I live in South Carolina. They really dont care if I have a third brake light at all, hell most people have red tape over their broken lights. Its real slack haha. Anyways I dont wish to bypass anything or take the warning bulb out so I think I will just go the easy way and connect a light to it and let it hang somewhere. Problem is I dont have the light or the connector. Would it be a pain to find one to replace it or should i just wire another socket to it like a cheap one from parts store? or is there an issuse of it being different? Thanks for the help guys, really.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
You don't have the wing do you? I was going to say take the harness from there, but it sounds like you don't have that. If not I would just get a connector and plug it in. Maybe extended it and run it on the rear fender inside the wheel well where the jack goes.
spudz29212MKIII
Columbia, SC
No I dont have the wing or the bulb w/connector. Would it be hard/too expensive to find a used/new connector? or just wire a new one there instead?
From toyotapartscheap.com a high mount stop light assembly is $66 thats horrible.
rayall01
901
Westfield, ma
Get the parts from a salvage yard, and do it right. You may be able to get away with it in your area, but that's not gonna help keep you from getting rear ended.
rayall01
901
Westfield, ma
jetjock;1302036 said:
Appears to be around 5% over the long term. Down from about 8% when they were mandated. Seems they don't do much for fatal crashes though:
http://tinyurl.com/d6zmw8
Fwiw...
5% is better than no%, and doing it right, if you can, is better than hacking. I do it right whenever I can, so that's the way I recommend it.
