Electrical Problem
cbutler
218
Regina, SK
I was hooking up a new boost gauge, and I tried to splice the wires for the light into the cigerette lighter like I heard from reading other threads. Not only does the light not work, but now somehow my tail lights, fog lights, and the rest of my gauge lights don't work. I must have shorted something out, but I have no idea where. I'm thinking that I must not of tied into the right wires on the cigerette lighter. Has this ever happened to anybody, or are there any suggestions.
Supracentral
10
Sounds like you hooked power to ground.
Go back, undo what you did and start over with a voltmeter in your hand this time. ;)
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yea i popped the fuse to my lighter and gauges 4 times when trying to plug my buddy's WB in the cig lighter port. something was wired wrong back there and it'd pop a fuse everytime we turned on the WB controller
cbutler
218
Regina, SK
I spent a lot of time checking for this short, but still no luck. I tried checking the fuses, and the gauge and cig. lighter were fine. There is no spot for a fuse where the diagram has it labelled for fog lights, this really confused me. Its a jza70 if this makes a difference. Also the power wire for the cigerette lighter (the red one) was soldered together, so I think this maybe where the problem is. I think I'm almost ready to give up and take it to the shop though.
