hi yall, just like the title said. i doing 2jz nat using 7m harness. i did pretty much as it post in here. i extended the harness and shorten them.i split the coil pack. i put 1&6 in the front and the rest in the back near the fire fall.i splice the sc300 alternator plug into the 7m harness and splice the 2jz o2 sensor with the 7m plug. but when i put the positive on the battery i hear some click, like spark. after that everything was off. i mean everything. no light. no power. everything is completely dead. did i just fried my ecu or fuses or wire? if you have any idea at, please help.
thank you, Jr
thank you, Jr
