Background on car:
1988 Supra Turbo. 165,000 miles. Targa.
Only mods are new Radiator, K&N stock air filter replacement, and wheels. I just installed (2) 12" electric fans onto the radiator. I took the power from the battery, to the switch/therm, then to a relay where I split the power to go to both fans.
Goal, to make about 350HP and 400torque to the rear wheels, most broad powerband possible. Driven everyday, weekends, and possibly a couple of track days and late night drags.
I've had no more cooling problems while driving since I did that install. (yesterday) The only problem I have now is that if I turn my car off, then back on again after about 5 minutes, it still has a bit of a heat-soak problem.
Question; would an electric water pump solve this problem, or reduce it in any way? I had an idea that I would be able to use a temp guage and keep the water pump going after the car was turned off, so that it would cool the motor down a little while after turning it off. And I wouldn't have to rely on RPM for the water to circulate faster.
On other threads, I read that they do make a water pump Part# WP136, but I wasn't sure, if applied, how well this modification worked for the car. I also don't even know if it would be worth it.
Ps. On a side note, so far, I have loved my electric fans. I was having a pretty bad overheating problem before, and now it's almost gone. Just an FYI. (Average heat during the day, 85F +/- 10F. Conditions; driving in stop and go traffic, highway, spirited back roads driving, short runs to lunch... and possibly a fiew burnouts...)
Thanks for reading.
Thanks for reading.
