Electric problem
MDCmotorsports
Indy 500
www.MDCmotorsports.com
ZFast300Z;902818 said:
stop overheating it
Worthless. Please don't post crap like this. Youre not funny. Its not funny.
ATL88Supra;903714 said:
there is a short somewhere, find it
At least use capital letters when trying to vague.
jetjock;903742 said:
^ I think he already knows that.
slasher: This is often caused by O2 sensor wires shorting to the manifold.
Thank you JJ for coming to the rescue.
Yes, its most likely your O2 sensor wires shorting out.
Report back and let us know what you find.
ZFast300Z
Trouble
Dec 15, 2007
102
Wisconsin
I gave an accurate response to the question being asked. He stated the EFI fuse keeps blowing. It keeps blowing because it is overheated.
Why is it overheating? Obviously there is an issue with excessive current traveling through the fuse more then likely from a short to ground. However the OP did nothing to help us in diagnosing or offering advice to him on what could be causing this condition. Sure you can say to check the O2 wires and see if they are shorting out. But how do you know, that he knows how to even check if the wires are shorted.
Simple information can go a long way in helping to get a far better response from me. Does the fuse blow in the KO/EO, KE/ER, the second the fuse is put in? Its simple, basic information that will help get a much better answer. It goes right along with "Whats the right size turbo for my car"...Im gonna tell you "A Big one...The biggest one you can find"
MDCmotorsports
Indy 500
Thats a better response. :icon_bigg
