I've been told there's no use in trying to change the fan, but I've also read drjonezz site (even if it hasn't been updated in awhile...I'm not sure if it has or hasn't.) and it says it's a good/cheap modification.
Any experiences or something?
4cefed.com said:#6 Lose that power robbing belt-driven fan
Objective - Reduce load on engine, improve cooling by removal of stock fan/clutch assembly attached to water pump.
Solution - Get a Permacool 14" High Performance electric fan (or equivalent, but make sure it flows more than 2500 CFM). Pull the radiator, install the fan on the radiator, remove the stock fan, reinstall the new radiator/fan assembly, wire it up and you're good to go. No big fan being turned by the crank means the engine can rev more freely, greater airflow by the electric fan means better cooling.
Cost? about $115 for the fan and a temp switch (to turn the fan on when the engine reaches a certain temp).
