if you're going to do this, you should use a
relay if you are going to do anything with fans at all... if you just want switched power to turn the fans on, run a 10ga wire from the battery to the relay, then 10ga to the fan(s).
with a switch in the car, take some 18ga wire, and send the "ON" side of the switch to the relay, the other side to a switched power source, which would be anything that becomes live when ACC is on.
i've personally never heard of tapping into the o2 sensor wires... what is this supposed to do? simply create a switched power source?
thats all youd need to trigger a relay.
