EGR question..
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
My supra is suffering from horrid throttle response and a ticking noise. This sounds like it could be comming from one of the two rear cylenders. Is it possible that this noise is from a leaking EGR cooler? Furthermore, could a leaking EGR cooler/Block off plates be the culprit of the horrid, horrid, horrid throttle response? I have no codes.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Ticking noise can certainly be caused by this.
Throttle response... that's tougher. It would have to be a really big leak to affect your turbo spool - if you even have a turbo. I can't imagine this affecting an NA engine much at all.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
my CPS timing was off, causing the throttle response to be horrible, and the engine to sound like it had a dead cylender/EGR leak. I thought i did it to spec the first time, and the second time, but the thrid time was the charm.
