EGR Flange help>>>
David D
53
Califfornia
Is it ok to reruse the EGR flage gasket that attaches to the side of the intake manifold? if i replace the gasket will a paper felpro type gasket suffice?
thanks again guys for the help.:icon_bigg
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Rennat;1179090 said:
replace it. a "paper" gasket is fine... i think the one i used was paper... and mine doesnt leak.
Yes a felpro is all you need. The 7M doesn't use any metal gaskets unless they're no the exhaust side. The gaskets they use are a paper composite high temp gasket. Some gaskets used on the 7m look like the head gasket itself, a lead looking gasket with metal mesh.
Mikek3
86
South Florida
i know^^^^ try putting an EGR on with the motor in the car,i got it done but it was a huge PITA my advise is that if you reach around the front side and under the intake manifold its easier to get to those bolts after i figured that out it was much easier
