EGR cooler
turbodan
21
Roan Mtn, TN
i have a question? i was fooling around with my supra today and i noticed it didn't have the EGR cooler on it. can the car run without it or will i need to find one and put on it. the owner of the car before drove it without it, im just curious about.
Thanks for any info,
Dano
RedGT
94
Baltimore, MD
The egr cooler is just a crossover routing the exhaust gasses around the head. if you are running without an egr system it is not needed, you can just block off the holes. I dont recommend running without an egr system however without an aftermarket or jdm ecu.
turbodan
21
Roan Mtn, TN
aright thanks RedGT thats all needed to know because the whole set up isnt there
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
If you don't have the cooler plate on the back of the head there is a port back there that you need to tap and plug. I you leave this open exhaust and or flame will poor out of there causing at the very least a drop in engine performance and a laggier turbo. It will also burn thru the heater coolant hose and anything else within close range. It will also be very loud. :aigo:
However if its already plugged or welded (not a good idea due to warping of the head) then you should be fine.
turbodan
21
Roan Mtn, TN
ok man yea its not plugged and how does all this hook up and how does the exhaust run to it and i jus buy a cooler for it
RedGT
94
Baltimore, MD
Heres a pic of the EGR system. If you have a JDM engine like I bought there were just some steel blockoff plates that went over the passage on the head where the exhaust gasses come from and one one the intake. I bought the egr cooler and gasket from a local toyota dealer and bought the rest from the classifieds on here. If you ever need help with how things bolt together the online TSRM and EPC is a great way to find out.
http://www.cygnusx1.net/Supra/Library/EPC/291210/catalog.aspx?F=2501&P=1
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
I dont reccomend running without working EGR w/o JDM ECU, B/C you will run lean in mid throttle.
Should you decide to disregard my advice, get block off plates. DO NOT run the car with that open. Guess whats right behind it? Your brake lines. With that open you will dump hot exhaust onto them, boiling your brake fluid, and when you hit your brakes the pedal will go to the floor and you will likely crash.
turbodan
21
Roan Mtn, TN
yes guys i put the whole EGR set up on there and its all complete finally. its a really easy set up lol cut again thanks for the info and help
